Remove Advanced Pulldown from P2 Footage
Matthew Sonnenfeld
on May 21, 2013 at 5:24:48 pm
Hello,
Is there any way to remove advanced pulldown from 1080/24pA material from an HPX170 within Media Composer?
Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
2011 Macbook Pro 17", 2.3 Ghz Quad Core, 16GB RAM
AJA IoXT
Adobe Production Premium CS6, Avid Symphony 6, Final Cut Pro Studio 3
The College of William and Mary
Michael Phillips
Re: Remove Advanced Pulldown from P2 Footage
on May 21, 2013 at 6:02:10 pm
In file based world, you would be better served shooting native 23.976pN than trying to remove it later in post. You also get a 20% increase in storage capture with those P2 cards.
But that aside, open your clips in a 1080i/59.94. Then open those bins in your 23.976. A mix and match motion adapter will automatically be applied leaving you with 23.976 native for editing.
Michael
Matthew Sonnenfeld
on May 21, 2013 at 6:03:45 pm
Thanks Michael for the motion adapter advice.
Unfortunately 24pN options are not available in 1080 using DVCPRO HD. Only pA.
AJA IoXT
Michael Phillips
on May 21, 2013 at 6:10:13 pm
Ah... too bad. It has been a while since I have touched any of these formats. The latter will work for you though.
Michael
Shane Ross
on May 21, 2013 at 6:10:23 pm
The HPX 170 and HVX 200 and 200a make better images at 720p than 1080, in my experience. I ONLY shoot 720p 24PN with those cameras. Then cross convert to 1080 for delivery. Always looked great.
Shane
Little Frog Post
Matthew Sonnenfeld
on May 21, 2013 at 6:24:17 pm
Hi Shane,
That's typically my workflow for the 170 as well but unfortunately I had to be mixing with previous footage from a Blackmagic Cinema Camera, a 7D, and a GoPro Hero2 so I was trying to match as much as I could to keep everything playing together nicely.
I know, the amount of of mess here is astonishing!
AJA IoXT
