Clips in bin after exporting an AAF
Guy Handelman
on May 16, 2013 at 6:27:00 pm
I just began a job using Avid Media Composer 6.5.2 and created an AAF for the first time. On my previous job, when I created an aaf, a new sequence was created in the bin that had the same name as the sequence I exported but had the ".Exported.01" suffix. I would always delete these clips from the bin and go on with my life.
But on this job, when I created an aaf, it created not only the "*.Exported.01" sequence, but also created new clips for every piece of media exported with the aaf and titled them "*.new.01." Depending on how many clips are in the aaf, it could really slow me down to have to delete every single one of these "*.new.01" clips. Is there a way that I can make the bin hide these new clips or not put them in the bin or something to that effect?
Thanks in advance.
Michael Hancock
Re: Clips in bin after exporting an AAF
on May 16, 2013 at 6:32:19 pm
There's something in your .aaf settings that is making it do that (probably consolidate media). You can check your .aaf settings and change that, or do this:
Make a new bin - call it AAF or something.
Copy your sequence to it.
Make an AAF from the copy.
Delete the AAF bin.
Michael Hancock
Editor
