avid 6.5 ok for my machine?
Hugue Loiselle
on Apr 28, 2013 at 2:29:04 am
I have a MACbook pro
4G ram
snow leopard 10.6.8
NVidia g-force 8600
I know these are not the specs for 6.5 but if I change for Lion will it still run properly or do I have to get Avid 5.5?
Hugue
Shane Ross
Re: avid 6.5 ok for my machine?
on Apr 28, 2013 at 6:38:51 am
I have Lion...and am running 6.5. SO it should work fine.
Shane
Little Frog Post
James Beattie
on Apr 29, 2013 at 11:35:34 am
The biggest variable is whether you mac is 64-bit capable or not.
After that your processor speed makes a huge difference, especially if you are using AVCIntra material or long-GOP material.
Here is how you can tell if your machine is 64-bit capable. Surprisingly enough I have found many that are not after the upgrade.
http://www.maclife.com/article/howtos/how_check_and_see_if_your_mac_runs_64...
James Beattie
ACSR Elite/Avid ACI, Apple Certified Technician
Consulting for Workflow and Digital Technologies at Comprehensive Technical Group
