Link AVI or import or recaputre???
Bharadwaj Dayala
on Apr 20, 2013 at 10:31:37 am
I am new to video editing and media composer. I have a large number of clips captured in AVI format (details below)
Video
Format : DV
Codec ID : dvsd
Codec ID/Hint : Sony
Duration : 10mn 59s
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Encoded bit rate : 28.8 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:11:06:03
Time code source : Subcode time code
Stream size : 2.21 GiB (95%)
Encoding settings : ae mode=full automatic / wb mode=automatic / white balance= / fcm=manual focus
Now my question is:
1. Is this video quality good enough for a high quality dvd?
2. If so shall I AMA link the files or import them into media composer? At what settings?
3. Will recapturing directly into media composer will increase the quality?
Thanks in advance.
