Can you export 4 channels of audio out of Media Composer 6.5.2
David Ridenhour
on Apr 16, 2013 at 5:04:25 pm
Is there a way to export an H264 file with 4 channels of audio out of Avid Media Composer 6.5.2. I do not want to use an AAF or OMF to do this. Any help would be appreciated.
In the export settings I opened the audio tab and selecting the "Direct Out" radio button but it did not seem to make a difference. Any help would be appreciated.
David
Shane Ross
Re: Can you export 4 channels of audio out of Media Composer 6.5.2
on Apr 16, 2013 at 6:58:56 pm
You can only export multi-channel audio when you export SAME AS SOURCE, if I recall correctly. Then you need to compress to H.264 after that.
Shane
Little Frog Post
David Ridenhour
on Apr 17, 2013 at 11:35:03 am
Shane,
I did not know you had to select same as source. Thank you I will give it a try.
David
David Ridenhour
on Apr 17, 2013 at 2:12:21 pm
Thanks Michael and Shane. I was able to get the export with 4 channels of audio when I selected "Same as Source."
I appreciate it.
David
Michael Phillips
on Apr 17, 2013 at 1:26:14 am
From the Avid Knowledge-base:
http://avid.force.com/pkb/articles/en_US/Troubleshooting/Exporting-Quicktim...
Michael
