Media Composer to Media Encoder Workflow
Erick Wilczynski
on Apr 10, 2013 at 6:37:56 pm
I am working in a Post house and my Assistant Editor wants to transcode a Media Composer project with Media Encoder.
I told her a QT reference file would be efficient and there would no loss in quality through the channels. However, I suggest this as an experienced Final Cut editor and a lite Media Composer editor.
Is there a better workflow for this process?
Not using Media Encoder is not an option.
Thank you
-E
-vimeo.com/36013051 (reel)
-RambozMediaGroup.com (production house)
Shane Ross
Re: Media Composer to Media Encoder Workflow
on Apr 10, 2013 at 6:49:14 pm
If it's non-AMA media...if it is Avid media...then a ref QT works great. Avid cannot export ref QTs of AMA media...must be Avid codecs.
But you're right...
Shane
Little Frog Post
Fred Gasc
on Apr 10, 2013 at 9:14:59 pm
Talking about that,
Not sure if it's also possible to export QTref with longGOP medias either.
I beleive it isn't or it wasn't. Does someone confirms that? or has it changed?
Fred.
stig olsen
on Apr 10, 2013 at 9:18:46 pm
Can you drop in all the 3 files that QT ref creates? Does it treat them as a single clip? Stig
Shane Ross
on Apr 10, 2013 at 9:27:16 pm
Correct. Long GOP you can't do REF QT either.
Shane
Little Frog Post
Fred Gasc
on Apr 10, 2013 at 9:35:22 pm
Thanks Shane.
Fred.
Peter Groom
on Apr 12, 2013 at 10:43:09 am
I can confirm that Ive been unable to export a qu ref from a seq containing Long GOP media or AMA linked media.
Which brings forth a question.
I once had a long seq that had a single frame of AMA media left in it by accident, but this was enough to stop me being able to export the qt ref i needed.
Is there a way if having AVID show / highlight / identify any AMA media from within mountains of non AMA media?
Peter
Post Production Dubbing Mixer
