No Sound In Source Monitor
Sean Schmolz
on Apr 2, 2013 at 6:06:42 pm
Hi guys,
So I've got a very strange issue. When I play anything in the source monitor of Avid the audio bars are moving but nothing is coming out of the speakers. This is the same when playing the calibration tone. If I put a sequence in the source I get audio, and likewise a sequence in record. Anyone had this issue?
System is HP8760w Elitebook
Win 7 Pro 64
Avid MC 6.5.2
Running through USB 3.0 to Intensity Shuttle
To mixer
To Speakers...
Thanks in advance,
Sean
Mark Spano
Re: No Sound In Source Monitor
on Apr 2, 2013 at 8:21:33 pm
Is it possible the source has audio on tracks that aren't A1+2? If so, choosing Stereo on your audio mixer's output instead of Direct Out will route any non A1+2 audio out analog outputs 1+2.
Sean Schmolz
on Apr 2, 2013 at 8:40:02 pm
Unfortunately not, the audio is on tracks 1 and 2 and output settings are already on stereo.
Sean
John Pale
on Apr 2, 2013 at 8:52:14 pm
Are the source audio tracks muted?
Sean Schmolz
on Apr 2, 2013 at 9:00:26 pm
No they aren't. I have nothing playing calibration tone either.
Sean Schmolz
on Apr 3, 2013 at 11:24:33 am
Okay, so apparently it's a Blackmagic issue.
John Pale
on Apr 4, 2013 at 12:21:53 pm
Strange problem. I'm thinking its not a BMD issue. The card passes whatever audio is fed to it. sounds like Avid is only sending audio from the timeline.
Try creating a new user in Avid and see if the problem persists.
Sean Schmolz
on Apr 4, 2013 at 1:00:55 pm
Hi John,
Thanks for this - I've found that it is actually a Black Magic issue.
No changing settings, deleting MC states, creating users is gonna help.
I spoke to Black Magic, and a ridiculous limitation of this model is that without video, no audio comes through the box. So when trying to listen to music or voiceover in the source, no sound... Even if you turn off the video monitor on a sequence, no sound...
The website says compatible with Avid, but totally isn't.
Sean
John Pale
on Apr 4, 2013 at 2:37:06 pm
[Sean Schmolz] "I spoke to Black Magic, and a ridiculous limitation of this model is that without video, no audio comes through the box. So when trying to listen to music or voiceover in the source, no sound... Even if you turn off the video monitor on a sequence, no sound...
Wow, thats really surprising. Totally unacceptable, if you ask me. No way they should expect anyone to work like that.
Going to NAB? Maybe complain to Grant face to face.
Sean Schmolz
on Apr 4, 2013 at 2:41:07 pm
Yeah I found it a bit of a surprise too! Why would you design something like that?
I actually really like the box itself, so was pretty disappointed when I discovered this 'little' flaw.
I'm in England actually but if you're going, feel free to hurl some abuse.
John Pale
on Apr 4, 2013 at 2:58:27 pm
Too bad you are not on a Mac.
The AJA T-Tap is a really great inexpensive monitoring solution, but it only works with Thunderbolt.
Sean Schmolz
on Apr 4, 2013 at 3:00:13 pm
I'm thinking of the Matrox MX02 mini. Not too expensive, and does all I need. Might play audio as well!
John Pale
on Apr 5, 2013 at 7:17:40 pm
Both Matrox and Blackmagic have their issues with Avid.
AJA seems to be the best these days.
