Transcripts randomly change font.
Scott Davis
on Mar 19, 2013 at 4:26:29 pm
After carefully formatting my transcripts for Script Synch; I open one up and Avid has randomly chosen a font to display it in (which was not the one I chose) It is a very hard to read font and I want it to be the way I set it up. Is there a way to change it back without having to reimport the script and redo everything?
Scott Davis
View Scott Davis's profile on LinkedIn
Michael Phillips
Re: Transcripts randomly change font.
on Mar 19, 2013 at 8:50:00 pm
Highlight all the text in the script window, then go to the EDIT menu and select FONT. Form there set font and size and you're good to go.
Michael
Scott Davis
on Mar 19, 2013 at 8:55:09 pm
Your a genius!! Work perfect. Still curious what cause it to change.
Scott Davis
