Edit with video purchased through iTunes
andrew thompson
on Mar 19, 2013 at 4:05:10 am
Im trying to edit a video purchased through itunes store and have hit a brick wall. It won't import directly, quicktime won't record it and neither will SNAPZ Pro. Does anyone know how to break through this problem?
James Patterson
Re: Edit with video purchased through iTunes
on Mar 19, 2013 at 9:47:14 am
What format is it? If you need to convert it to be avid friendly try mpegstreamclip . It's free and works on mac and windows
Best
Paddy
Michael Phillips
on Mar 19, 2013 at 1:58:03 pm
It's a DRM issue. Same thing used to happen with songs purchased through iTunes - importing via QuickTime saw the DRM and refused to process - same thing for video I suspect.
Michael
James Patterson
on Mar 19, 2013 at 2:41:03 pm
Ah, the old DRM! I thought I read somewhere that apple had stopped using DRM on itunes? I don't tend to buy anything from itunes but it's good to have a heads up if the need ever arises!
Best
Paddy
Michael Phillips
on Mar 19, 2013 at 2:51:30 pm
They stopped it on music, not video... that's a whole different negotiation with the studios. I don't see that going away any time soon.
Michael
Bryan Roberts
on Mar 21, 2013 at 3:35:52 am
A quick google search should give you results on how to defeat it, I've had to do it a few times with an item I've purchased. I believe Lifehacker had the article? I think...
FCP / AVID EDITOR
Features : Television
http://www.DefiningFilms.com
andrew thompson
on Mar 21, 2013 at 5:17:37 am
Sadly I lost my battle with the DRM ... I ended up getting the episode in a torent. So much for doing the right thing.
