Chroma Keying Weird Issue
Duane Horn
on Mar 19, 2013 at 2:38:47 am
Hi There
I have been asked to fix a weird issue with a chroma key efffect. Its got me stumped. I am currently running Symphony 6.5 and with Boris Continuum 8 AVX. The footage was shot in xdcam format and 1080i 25fps. What we currently have is the following effects on a clip in this order
- Color Correction
- Resize
- BCC Chroma Key
- BCC Matte Chocker
Now when we have this applied there is a slight flicker around the edges. But if we removed the color correction the clip is fine. So for some reason the color correction is causing issues. Any advice on this issue would be much appreciated.
Regards Duane Horn
James Patterson
Re: Chroma Keying Weird Issue
on Mar 19, 2013 at 9:40:46 am
Are you playing back in draft quality or full? Sorry if it sounds like a basic question but it's amazing how many things that look like glitches are just due to draft quality playback.
Best
Paddy
