Slow export
stig olsen
Slow export
on Mar 9, 2013 at 5:19:44 pm
Im on a PC z820 and QT export (same as source - MXF) is much slower than Im used to from my old Mac.
Attached is a printscreen with the performance and CPU usage when Im exporting -
I dont know how to interpret it myself, but I appreciate your help!
Im running Q4000 for Avid, but I have also installed a GTX 690 card.
Jeff Greenberg
Re: Slow export
on Mar 15, 2013 at 12:46:58 pm
I'm guessing here from looking at your timeline - I couldn't tell if the filler/top track was rendered.
If it's not, Avid has to render it as it exports your file. If you rendered it first, your export should be faster. Also, same as source is mostly beneficial in export speed when all the video matches the render type...
The fastest export would be to do a QuickTime ref, and use Squeeze to compress into multiple formats.
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
© 2018 All Rights Reserved
