How to turn off auto import of QTs
Frederic Lumiere
on Mar 4, 2013 at 10:25:24 pm
I turned off all the options in the AMA settings (Auto link to AMA volumes, etc...)
Somehow, when I plug in a drive with QT on it, MC keeps on trying to import them. Anyway to turn this very annoying feature off?
Michael Phillips
Re: How to turn off auto import of QTs
on Mar 5, 2013 at 2:59:52 am
v6.5 brought the capability of turning off auto-moount which is the issue you are seeing and want to turn off.
Michael
Frederic Lumiere
on Mar 5, 2013 at 3:34:31 am
That's what I turned off somehow it still mounts the drives and opens the same bin over and over...
Michael Phillips
on Mar 5, 2013 at 11:48:38 am
Maybe it is because this drive had been mounted before? What happens if you unmount it from the system. I am not in front of an MC right now, but at the bottom of the File menu there is something about mount/unmount. Try removing it and see if it helps with the automount turned off.
Michael
John Pale
on Mar 5, 2013 at 1:48:40 pm
Did you quit MC and relaunch? some of the AMA prefs need that to take,
