MC6 exported video to Pro tools.
Moses Ross
on Feb 13, 2013 at 5:55:43 pm
I exported 6 reels of footage that is edited in Media composer 6 in Windows 7.
Each footage plays about 19 minutes and weighs about 15 GB. So I converted it using Emicsoft video converter with the settings of 720*576 frame size with 24 frame rate per second, which was all done in in Windows 7. When I opened the converted files in I Mac its shows a different resolution like 1024*576 and 23 fps. I tried other video converters like MPEG streamclip and Xilisoft and those didnt work too.Finally I converted them in Adobe premiere pro CS6 with the above mentioned settings. The converted video looked fine when I opened them in Imac, but when I imported it to Pro tools(I mac), the softwares showed that its a corrupted file and cannot be opened.
So is there a way to open the MC6 video files (Windows 7) in Pro tools (I mac) so that I can finalize my dubbing.
Shane Ross
Re: MC6 exported video to Pro tools.
on Feb 13, 2013 at 6:58:54 pm
Why not export as H.264 directly from Avid?
Shane
Little Frog Post
Michael Phillips
on Feb 13, 2013 at 7:20:12 pm
Have you tried AAF with embedded video media?
Michael
Moses Ross
on Feb 14, 2013 at 3:33:59 am
Actually I can do the export in the required format in MC6 but it will take more time for a single 19 minute video itself. Thats why I had to go for time saving stuffs like exporting it in save as source format and then converting them in video converter.
Shane Ross
on Feb 14, 2013 at 3:56:59 am
Here's how to do it faster than real time...as H.264. Low res, only for review...but it works for everyone I show it to.
http://lfhd.net/2012/08/31/exporting-low-res-qt-from-avid-fast/
Shane
Little Frog Post
Moses Ross
on Feb 18, 2013 at 3:33:25 pm
It is really helpful . Thank You.
