RED footage to AVID then to RESOLVE with output of 4k
Ricky Milling
on Feb 11, 2013 at 3:32:42 pm
Hi, basically i have been asked to edit a 4k short film which they will want to have the final output at 4k. From what i understand i can link to the original material through AMA, then export a AFF for the grader in resolve.
My question is that as AVID cannot create a sequence high than 1920x1080 im hoping that the AFF file will no limit the grader to 1920x1080 and instead be able to grade with the full 4k image and output from that?
Ive done a round trip before, however the spec was only for 1080p.
(NOTE IM GOING TO POST THIS IN THE RESOLVE FORUM ASWELL)
Shane Ross
Re: ED footage to AVID then to RESOLVE with output of 4k
on Feb 11, 2013 at 3:44:12 pm
Avid tops out at 1920x1080. But the workflow is to export an AAF that is imported into Resolve that then telinks to the 4K originals.
Shane
Little Frog Post
Oliver Peters
on Feb 11, 2013 at 4:16:53 pm
Check out the workflow I posted here:
http://digitalfilms.wordpress.com/2013/01/12/offline-to-online-with-4k/
- Oliver
Orlando, FL
http://www.oliverpeters.com
Michael Phillips
on Feb 11, 2013 at 4:21:11 pm
Just remember you will need the $1K version of Resolve to output greater than 4K.
Michael
Ricky Milling
on Feb 11, 2013 at 4:34:43 pm
Hey guys thats great news, i thought it would work that way, but wanted to make sure before i took on the project. That web guide is great and just what i was after. As for the Resolve part, thats someone elses job to grade and export :-)
