I get this: Exception: ADM_COREAUDIO_UNDERRUN, detected:2147483648
Nitzan Saar
on Feb 5, 2013 at 9:14:00 am
Hey!
I work with Media Composer 6.5.2 on mac and every time I try to play the Sequence I get this:
(I have SO 10.7.5)
Can Someone Help Me?
Thanks!!
Robert Ober
Re: I get this: Exception: ADM_COREAUDIO_UNDERRUN, detected:2147483648
on Feb 7, 2013 at 4:04:54 pm
[Nitzan Saar] "I work with Media Composer 6.5.2 on mac and every time I try to play the Sequence I get this:
(I have SO 10.7.5)"
Hey,
What audio interface are you using? If some form of Avid/Pro Tools interface make sure you have the latest driver(s) installed. Also, make sure you match the sampling rate in the Mac AudioMidi utility to your timeline sample rate.
I was getting this last week but have not gotten it after doing the above and a COLD BOOT. I also updated to 6.5 yesterday and so far have not seen the issue but I have not played a timeline much yet with 6.5 .
A Cold Boot means shutting the system completely down (not just restart), count to 10 and the boot the system. Booting to safe mode is also a good idea to clean caches, then boot normally.
I answered this in another forum, was that you?
Good Luck,
Robert A. Ober
