E-mail Notification in MC 6.5
Phillip Byrd
on Jan 31, 2013 at 10:32:01 pm
Media Composer has had a nifty e-mail feature that will notify when a render or transcode is completed.
I'm running MC 6.5 and I'd like to use that feature. I can find instructions for its use in help and in the editing guide. But I can't find the set-up as described. It seems it should be found on the settings tab. But it isn't there.
Am I looking in the wrong place or is it a feature that has fallen out of the application?
Glenn Sakatch
Re: E-mail Notification in MC 6.5
on Feb 1, 2013 at 3:20:56 pm
in 6.5 you should have a tab called email under settings.
If you don't see it, check that your settings is set to show all settings, not just base or active.
(click the hamburger button , top left corner under the bins button, and next to the user button.
Glenn
Phillip Byrd
on Feb 1, 2013 at 5:55:40 pm
Thanks Glenn.
Found it!.
phil
Phillip Byrd
Brandenburg Productions, Inc.
Montclair, NJ USA
