Backward compatible sequences?
Eli Brown
on Dec 27, 2012 at 2:24:44 pm
I have a job coming from an Avid MC 5.5 and am wondering if there is a way to do a color grade in resolve and then reconform it without having MC5.5 on my system. I have MC6, so I was planning on opening their earlier version sequence and exporting the AAF to Resolve and roundtripping back to MC6... but then, how to get that sequence back to MC 5.5? Thanks in advance for any ideas!
Eli
• postbrooklyn •
creative. post. production
@postbrooklyn
Michael Phillips
Re: Backward compatible sequences?
on Dec 27, 2012 at 9:24:15 pm
The rendered MXF media is compatible, and you can open sequences in earlier versions but it depends on if you are using something in v6 or later that is not available in 5.5. For the most part, I think you're good.
Michael
Neil Patience
on Dec 27, 2012 at 9:26:36 pm
Hi Eli
Avid 5.5 can read Avid 6 projects with the limitation that if you use a MC6 feature that is not in 5.5 this will not translate.
I found this thread where several people confirm this.
http://forums.creativecow.net/thread/45/883647
best wishes
Neil
http://www.patience.tv
Pat Horridge
on Dec 28, 2012 at 10:17:55 am
Yes backwards compatability is still pretty robust despite the many recent developments. We have a lot of V5.5 to V6 & V6.5 projects moving around.
As always best to recreate a fresh project with the version of MC you are on and copy just the bins you need. Yes MXF media is compatible so if you have an effect thats not backwards supported just mix it down.
This is one of the reasons I'm so pleased Avid have resisted the easier "x" route of completely redesigning the software and breaking that compatability model they've protected for so long.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Eli Brown
on Dec 28, 2012 at 1:28:49 pm
Thanks for the info! Glad to hear it works that way.
• postbrooklyn •
@postbrooklyn
