1080i proxy
John Heagy
1080i proxy
on Dec 6, 2012 at 11:09:38 pm
With DNx36 not supporting 1080i60 or 1080p30 what are people using for a 1080i proxy format?
The next DNx flavor is 100Mb... way too big! ProRes proxy supports 1080i but we'd prefer a cross platform encodable format. After that it's XDCamEX 35Mb but a long GOP proxy would be asking for trouble, no?
Unfortunately SD DV25 anamorphic may be the way to go.
Back to the future!
John
Shane Ross
Re: 1080i proxy
on Dec 7, 2012 at 1:19:22 am
We import all the footage at 10:1m. Have to do this in an SD project in order to get that.
Shane
Little Frog Post
John Heagy
Re: 1080i proxy
on Dec 7, 2012 at 2:11:07 am
[Shane Ross] "10:1m"
Ok now that's back to the future!
We'd need an easy to encode to codec. Merdian omf is anything but.
I'm very surprised by the lack of a suitable 1080i proxy format.
John
Shane Ross
Re: 1080i proxy
on Dec 7, 2012 at 2:53:26 am
10:1m is MXF. Avid doesn't do OMFI anymore. Go with DV if you want. Either way, for low res 1080i you'll. You'll to go SD
Shane
Little Frog Post
Job ter Burg
Re: 1080i proxy
on Dec 7, 2012 at 7:17:13 pm
I think you can still do OMF, if you set the Media Creation settings appropriately. But indeed, Meridien in MXF is also possible.
Eric Johnson
Re: 1080i proxy
on Dec 8, 2012 at 12:22:17 am
Have you tried changing the "format" of your project to 1080p29.97 and using DNxHD 45?
John Heagy
Re: 1080i proxy
on Dec 10, 2012 at 5:57:19 pm
Thanks for the suggestion didn't know about DnX 45 but I think that will be too high a data rate.
I'm trying to fast import HDV but HDV is not listed in the Resolution pulldown. Is it possible to fast import HDV.mov or other wrapper?
John
