Saving to Different MC Versions
Chip Hess
on Nov 28, 2012 at 12:14:19 am
My workplace has 6 and I am considering upgrading to 6.5.
Any pitfalls in moving projects between the two versions?
Can I bring home a 6 project, edit in 6.5
and then save it in such a way to be able to open in 6 at work?
Michael Hancock
Re: Saving to Different MC Versions
on Nov 28, 2012 at 12:21:18 am
[Chip Hess] "My workplace has 6 and I am considering upgrading to 6.5.
Any pitfalls in moving projects between the two versions?"
No.
[Chip Hess] "Can I bring home a 6 project, edit in 6.5
and then save it in such a way to be able to open in 6 at work?"
Yes.
Best practice - make a project on 6.5 with the same name as the project on v6 and copy/paste the bins from the v6 project into the 6.5 project. When you go back to work, bring the v6.5 bins with you and paste them into the v6 project.
I did this over the weekend - v6 at work, tried the 6.5 trial at home, brought the 6.5 project to work and opened it in 6. Didn't even follow my own advice to transfer just bins and I've had 0 problems. Been bouncing Avid projects around among different versions for the last 8 years and never had an issue.
Michael Hancock
Editor
Shane Ross
on Nov 28, 2012 at 1:54:19 am
Just make sure to avoid features in 6.5 that 6.0 doesn't have. The only issue I ran into was the amount of real time audio tracks I used. Because I use 6.5 and everyone else uses 6.0. They couldn't play back all of my audio at the same time. But that's a minor thing.
Shane
Little Frog Post
