Mountain Lion compatible Serial-to-USB adaptor recommendation
Dustyn Gobler
on Nov 24, 2012 at 1:55:15 pm
Can someone recommend a Serial-to-USB adaptor that is compatible with OS X Mountain Lion. I need deck control through Avid Media Composer. Thank you in advance,
Dustyn
Bob Zelin
Re: Mountain Lion compatible Serial-to-USB adaptor recommendation
on Nov 24, 2012 at 5:11:14 pm
it would be easier for you to purchase an AJA or Blackmagic Capture card, which has RS422 built in.
But if you want to stick with that old AVID hardware -
you need a Keyspan USA-19HS, which is a USB to RS232 adaptor, and then this goes into an Addenda Electronics RS2/8, which is a RS232 -RS422 adaptor.
Bob Zelin
