Clip names and effects
Scott Davis
on Nov 16, 2012 at 6:49:57 pm
When I add more than one effect to a clip; the clip name no longer shows and only the name of the effect shows. Is there a way to have it not do this?
Scott Davis
View Scott Davis's profile on LinkedIn
August Anderson
Re: Clip names and effects
on Nov 16, 2012 at 7:47:26 pm
Can you give some more details? From what you're describing, it sounds like a bug. That definitely should not be happening.
When you say that you're adding more than one clip, you're dragging and dropping the effect holding the OPTION key, right?
August Anderson
QRSlate QR-Code Film Slate
• App: http://www.qrslate.com
Scott Davis
on Nov 16, 2012 at 8:08:23 pm
Yes. Dragging an effect and then option dragging another effect. Clip name changes to "3D warp"
Running Symphony 6.0.3
Mac OS 10.7.5
Scott Davis
August Anderson
on Nov 16, 2012 at 8:27:19 pm
Unfortunately, as far as I know, that's just part of Avid. I've never seen it act differently.
I can see how it'd be pain in some situations.
Can anyone confirm if this is just part of Avid? That would be a nice thing to toggle on/off.
August Anderson
Scott Davis
on Nov 16, 2012 at 9:10:32 pm
That's what I feared. It makes it hard to ID clips in the timeline for the archivist.
Scott Davis
Pat Horridge
on Nov 17, 2012 at 10:00:06 am
I had this at one stage during the beta testing of V6 but can't remember the cause.I'd suggest creating a new user setting first.
Then check timeline settings clip text.
If no joy try a new project and copy the bin into it.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Michael Phillips
on Nov 17, 2012 at 4:16:33 pm
Is the archivist going through the timeline clip by clip, or are they using one of the reporting methods out of a MC timecode such as EDL, XM, TAB, etc. and working from that? In those cases, the clip persists as needed. But knowing exactly how the archivist wants to work would probably lead to one solution over another.
Michael
Pat Horridge
on Nov 18, 2012 at 8:07:27 am
Or copy the sequence to an empty bin and turn on show reference clips.
Pat Horridge
VET
