Unknown Compression Type error
Mark Norgate
on Nov 9, 2012 at 8:40:34 am
I'm trying to conform a sequence and all has worked fine except this little run of clips that displays the error 'you cannot import this type of clip into a bin' then I get an UNKNOWN_COMPRESSION_TYPE error. In the bin where I import the AMA clips to, under video it displays Unsupported (HD1080i). This is a HD1080i project and all the other footage is perfectly happy.
Help?!
Mark Norgate
Re: Unknown Compression Type error
on Nov 9, 2012 at 8:42:57 am
I'm running a PC with Avid 5.0.3 if that helps.
