Sorenson Squeeze/Compressor Clustering
Sam Barton-Humphreys
on Nov 8, 2012 at 4:33:07 pm
I'm looking to find the fastest/best quality export workflow from MC 5.5, we have two MacPro's on our network. Currently I export a Quicktime reference from Avid and import to MPEG stream clip. From what I understand MPEG stream clip does not have the capability to cluster. I know Compressor has cluster capabilities but is this compatible with the Avid DNX145 codec? If not does Sorenson Squeeze have a cluster function?
Many thanks!
Ricky Barrow
Re: Sorenson Squeeze/Compressor Clustering
on Nov 8, 2012 at 5:20:47 pm
Sorenson will work with Avid DNxHD if Avid is installed on the computer OR if you have installed the codecs, which can be downloaded for free and installed.
Ricky
