Tape won't capture due to time code breaks - wild or batch
Rosie Walunas
on Nov 4, 2012 at 11:24:25 pm
I'm trying to capture a mini-DV tape 4x3 @ 29.97.
When I log the clip it ends up stopping at a seemingly random point because of "time code discontinuity" or it "can't find the pre-roll."
When I try to capture it wild, it says I've inserted a dropframe tape and that I should insert a nondropframe tape. When I change the dropframe setting to nondropframe, it says that a dropframe tape should be inserted.
I also tried unchecking the boxes so that the tape will "Stop capture if a bad frame is detected."
What else can I do? The tape doesn't seem to be bad.
Thanks.
