Can't load MXF files into Media Composer / Media Tool
Troy Williams
on Oct 25, 2012 at 8:29:07 pm
Hi there, Avid noob here.
So I've got a large number of files converted to MXF from DaVinci Resolve (specifically, MXF DNxHD 1080p 36 8bit, 23.98). I'm trying to load them into Avid.
I've copied them to R:Avid MediaFilesMXF1. I've launched Avid, loaded the Media Tool, pointed it at R:, checked off "Master Clips" and "Media Files". No joy, much frustration.
What am I doing wrong?
Michael Phillips
Re: Can't load MXF files into Media Composer / Media Tool
on Oct 25, 2012 at 9:42:06 pm
Just want to make sure that what you list as R:Avid MediaFilesMXF1. is really R:Avid MediaFiles/MXF/1 where it is three embedded folders at the root level of the R drive.
If so, then another way to bring in just that folder's media is from the bin, File Import - then navigate to R:Avid MediaFiles/MXF/1 and inside the 1 folder, select the msmMMOB.mdb file. All clips in that folder will now have pointers in the bin.
Michael
Troy Williams
on Oct 26, 2012 at 2:00:37 am
Argh... that was a typo on that post.
Yes, the directory is R:\Avid MediaFiles\MXF\1
Michael Phillips
on Oct 26, 2012 at 1:17:46 pm
Were you able to see the files? I also want to make sure that these are DNxHD files ending in .mxf and not DnxHD files ending in .mov correct?
Michael
