Avid Format Question
Matthew Stewart
on Oct 18, 2012 at 6:10:02 pm
I'm trying to import an h.264 file that is from a dvd, the video is sized 960 x 640, is there a way to immport this into avid and set it up for that size? When I create a project I can only select 720 or 1080. How I can I import the file and edit it at the best resolution possible and export it without losing any original quality?
Shane Ross
Re: Avid Format Question
on Oct 18, 2012 at 6:31:21 pm
Avid only works in broadcast frame sizes. And that file is neither. Your options are 1920x1080, 1280x720, 720x486 and 720x480. If the file came from a playable DVD, it should be 720x480.
Shane
Little Frog Post
Matthew Stewart
on Oct 18, 2012 at 7:23:14 pm
ok, thanks!
Trevor Asquerthian
on Oct 18, 2012 at 7:44:13 pm
You could import them with 'do no resize smaller images' in the next size up broadcast raster - and do a crop back down to the native size at the end in some other programme (compressor?)... if you really need to keep that size.
