when playing dnxHD 175x 108024P Exception: Your attached hardware is reporting an unexpected frame rate.
Sanrj Patil
on Oct 5, 2012 at 6:21:01 pm
Exception: Your attached hardware is reporting an unexpected frame rate.(when playing black frame evey other frame)
Plese ensure hardware video formate settings are correct.
if settings are correct, please save your work, power down your system and attached hardware, and restart to restore normal optation.
avid symphony 6.0.3
Kona 3G
HPz800 quadro5000 48GBRam 12core
any idea?
Terence Curren
Re: when playing dnxHD 175x 108024P Exception: Your attached hardware is reporting an unexpected frame rate.
on Oct 6, 2012 at 6:16:49 pm
24 or 23.98?
What does the Kona control panel say it is seeing?
Terence Curren
http://www.alphadogs.tv
http://www.digitalservicestation.com
Burbank,Ca
Sanrj Patil
on Oct 6, 2012 at 11:33:07 pm
24p
If I select Psf in kona 3g I dont get error
But selecting P in kona 3G giving problem
Uwe Klimmeck
on Dec 12, 2013 at 7:52:03 pm
Have a similar thing on Mac and BMD when I try to export.
If I create a new user profile including export settings it. usually fixes the Problem for a Day or two.
So you might give it a try.
FC Studio / DLpro / SDconnect / Dual 2.7 / Dual 1.4 / Dual iPod / http://www.fcpmunich.com
