AVID HD to SD XDCAM workflow
Miłosz Koziol
on Oct 4, 2012 at 7:08:34 pm
In very near future I ll be editing a 4 camera political tv programm. It`s aimed at local TV station, wich still broadcasts in SD. I have 4 cams - 2 EX-3 wich can only record in HD and 2 EX-1r. I planned to shot it on 1080p and later multicam it or edit it directly on a timeline (due to budget here is no mixing at all). I`ll export rendered sequence into XDCAM broadcast PDW1500. Now...
Firstly I cannont export sequence on ama can i ?
Secondly - should I drop 1080p for 720i since PDW1500 cant ingest progressive material and since I have like 4 hours to deliver the show after we finish recording (it will be aired same day it was shot).
Thirdly, I plan to edit it directly on the set with macbook pro and export it to PDW1500 XDCAM - should I use a ilink or SDI from ultrastudio extreme? Can I maybe ingest an HD sequnce and shrink it to SD in real time?
I`m really confused...
© 2018 All Rights Reserved
