Best export settings for Avid Media Composer 6?
Nicole Favale
on Sep 9, 2012 at 11:06:13 pm
What would be the best export setting for me to get the highest quality .mov? I can't use "same as source" since it will be too big for a DVD. I used to use Apple Pro Res, but that does not seem to be an option here. The image below shows my options. Thanks!
Job ter Burg
Re: Best export settings for Avid Media Composer 6?
on Sep 9, 2012 at 11:15:43 pm
Don't use the QT encoder. If you set Custom QT export options in Media Composer, you will be using it. Export Same-As-Source or QT Ref and use Sorensen Squeeze to create something that fits your delivery format.
Nicole Favale
on Sep 10, 2012 at 4:29:02 pm
Ok thanks! I checked out Sorenson Squeeze and can't afford it. Should I get Compressor 4? I could export same as source and then use that, right?
Job ter Burg
on Sep 10, 2012 at 4:59:54 pm
If you own MC6 or SY6, you own a Sorensen Squeeze license.
Paul Poirier
on Jun 27, 2014 at 12:04:43 am
Newbie here....
but it's my understanding that you can't send a QT reference to Sorenson if you're using AMA. What is the best option for exporting to youtube if you're using AMA?
thanks
