can you delete an audio track from a subclip?
Caitlin miller
on Aug 10, 2012 at 9:54:17 pm
I had an AE sync a bunch of interview footage and make subclips in order to join the video w/ the ISO. We have no back up audio, so when syncing I asked him to include the camera audio in the subclips just in case the lav audio ins't good. After looking at the subclips today, I realized that the camera audio levels are extremely high and peak constantly. I would like to erase only the camera audio from the sub clips... is that possible? I don't want to have to go back and re-sync everything all over again, I'd like to just get rid of the camera audio.
Just so it's clear, here's our syncing and subclipping process:
1)lay the ISO out on the timeline and sync with the camera by slate
2)On the first synced frame of video and ISO together:
-Match frame the video. Make a subclip of it.
-Match frame the ISO. Make a subclip of it.
3)Select those two sub clips, then go to:
Bin > Autosync
-Sync by in point. Then, choose "Keep audio on clip with video" to include the camera audio in the sub clip.
Caitlin
Richard Sanchez
Re: can you delete an audio track from a subclip?
on Aug 10, 2012 at 10:48:45 pm
Load the sub clip into your source monitor. Deselect the tracks you want to remove, and drag it back out into a bin. New subclip, minus the tracks you don't' want.
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
Caitlin miller
on Aug 11, 2012 at 3:19:46 am
Great! Thanks so much
Pat Horridge
on Aug 11, 2012 at 8:30:29 am
if you hit delete on a master clip it will offer you the option to delete the media and what parts of the media. so you can select the audio only. But that gives clips withaaudio showing offline.
normally you can't modify a clip if it has media attached. but hold ctrl shift and link becomes unlink you can then modify the clips tracks and then relink the clip to connect the video.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
