Script Sync question
John Castelli
on Aug 8, 2012 at 10:36:21 pm
Hey all,
We just had Script Sync added to our arsenal at work, and I just had a quick question on it having never used it myself.
Do the scripts need to be (or work better) if they are formatted a certain way? Not from the standpoint of file extension, but the format of how the script is written on the page?
Thanks for your time and help, I appreciate it!
John
Richard Sanchez
Re: Script Sync question
on Aug 8, 2012 at 11:59:22 pm
Coming out of Microsoft Word, save as Plain Text, Text Encoding: MS-DOS, include line breaks, and Allow character substitution (if necessary)
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
Michael Phillips
on Aug 9, 2012 at 1:07:04 am
Are you referring to a script in screenplay format or a transcript? In both cases, formatting and elements you don't want indexed need to be considered.
Script:
In screenplay formats, you need to ensure that only the dialog is being indexed and not all the other Action, Scene Heading, etc. This is done by ensuring that all dialog starts "n" number of spaces of left margin. Screenplay application like Final Draft do this as a matter of course and all you need to do is "save as text with layout" to preserve the look. In the script settings, you can select "dialog" from the script and it will do the offset identification for you.
Transcript:
Less formatting that a screenplay, but still some considerations as to items you do not want indexed and synced. For example, for an interview type transcript if the interviewer and interviewee are labelled, then you want to make sure there are [ ] around that. The brackets tell the indexing engine to ignore what's in between. Same for timecode, and anything else that would not be part of the dialog being spoken in the footage.
Also, for long transcripts, you will want to have more granularity since the indexing is line based. You can make the amount of characters per line shorter by setting the margins larger before saving as text with layout.
Michael
Michael Phillips
John Castelli
on Aug 9, 2012 at 4:50:07 pm
Great info - exactly what I needed. Richard gave me the other key element that I needed (even though I did not know I needed it at the time!). Appreciate the help and quick response!
_____________
John Castelli
Editor
John Castelli
on Aug 9, 2012 at 4:48:56 pm
Thank you for your help. Between the info I received from you and Michael I figured it out pretty quickly. What a great tool.
_____________
John Castelli
Editor
