Cant import .wav getting exception disk_invalid_filename_syntax
ross byron boughton
on Jul 31, 2012 at 6:19:14 pm
am using MC 5.5 on a mac
i have the video files in however i cant get the .wav files files to import
tia
Ross Byron Boughton
Editor / Webmaster / Sound Designer
http://www.inch.com/~bellevue/
Richard Sanchez
Re: Cant import .wav getting exception disk_invalid_filename_syntax
on Jul 31, 2012 at 6:29:56 pm
Do your filenames have illegal characters? Exclamation points, commas, periods, and especially slashes are a no no.
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
ross byron boughton
on Jul 31, 2012 at 6:50:25 pm
T13.wav
T08.wav
pretty straight up rec by soundman to a card then i put the contents of the card with the file projects
i know i am missing something tiny 24bit 48 k
thanks RB
Ross Byron Boughton
Richard Sanchez
on Jul 31, 2012 at 7:00:48 pm
What about the file path that your clips are in? I've seen the Avid give that error if, for example you files are in a folder called "7/31". There's a slash in the name and that will trip up the Avid.
Richard Sanchez
Los Angeles, CA
ross byron boughton
on Aug 1, 2012 at 12:32:18 am
i bet that's it when i get back to work in the morn will check it out
fingers crossed
thanks and then post thanks rich
Ross Byron Boughton
ross byron boughton
the Answer Cant import .wav getting exception disk_invalid_filename_syntax
on Aug 2, 2012 at 2:02:27 pm
yes rich thats what it was i had the .wavs in a project folder with a long name and dates IE 7/20/24
best Ross b
Ross Byron Boughton
