Recommend NVIDIA Mac Driver - MC6
Alex Olinger
on Jul 28, 2012 at 11:59:27 pm
I`ve been setting up a "Harpertown" Mac Pro Avid set up with a GeForce GT 120, running Mac OS X (10.7.4). Unqualified OS I know, but I`ve heard no major issues from using it over 10.7.3
I am having trouble figuring out what Nvidia drivers are supported with Avid MC 6.0.1.1
I`ve browsed through the Avid community forums, but all of the documentation is for recommended Nvidia driver packages on Windows.
I did find this Mac driver package on the Nvidia site, support GT 120
http://www.geforce.com/drivers/results/44848
For those running similar set ups, which driver are you running?
Elvin Jasarevic
Re: Recommend NVIDIA Mac Driver - MC6
on Jul 29, 2012 at 4:21:22 am
Hi Alex,
Here is link of Avid supported systems with Hypertown. You will find that 8800GT is supported only and only Mac with 10.5.x. (not 10.7.4).
However it doesn't mean that will not work with some basic operations.
I am testing beta 6.0.2 which will be released in 2 weeks time, and there is still problem on Digital Cut on Mac.
We have tried 4 qualified mac's and all of them have problems, even on local/fast HDD's. It happens randomly and you also need to have console window in order to notice this bug.
When you doing Digital cut, also if you click "about this Mac" it will stop. (it tells you about quality of program)
Mac with 5.5.x and PC with 5.5.x or 6.0.1 there is no issues on DC, and only happen on Mac V6.
Considering that this is first ever 64Bit application as well with support 3rd party I/O hardware ever, we could expect some problems but not such a basic miss.
Please check bellow for specs and good luck.
Elvin
http://cdn.pinnaclesys.com/supportFiles/attach/422411/MacQual_MC_SY_v6_10_1...
John Pale
on Jul 29, 2012 at 3:45:18 pm
It's my understanding that Avid does not use the GPU for any acceleration on the Mac. Any card qualified by Apple on your machine is fine with Avid. Apple provides all graphics card drivers in the Mac OSX install and software update. Normally, you do not need to download them directly from Nvidia or AMD. Avid on Windows does use some GPU acceleration (which is minimal compared to Premiere Pro or Final Cut Pro X, which use the GPU extensively), thus there are recommended driver packages to use on the Windows side.
