It is possible to conform WITHOUT Cinema Tools?
leo Fallas
on Jul 24, 2012 at 5:12:40 pm
On an AVID or Premiere Station in mac?
thanks.
Richard Sanchez
Re: It is possible to conform WITHOUT Cinema Tools?
on Jul 24, 2012 at 5:28:20 pm
We need more information. Are you conforming frame rates? Did you offline, and you're now trying to conform to an online format? Conform can refer to a few different things.
Since you mentioned Cinema Tools, I'm assuming you have something shot at 29.97 that you want to conform to 23.976 which is a common thing done in Cinema Tools. There is a console command that will help. Go to the Console and type "ignoreqtrate true". When you import your 29.97 footage in your 23.976 project, it will play out at 23.976 making it look slow.
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
leo Fallas
on Jul 24, 2012 at 6:04:51 pm
thanks richard.
I'm migrating from FCP to AVID or Premiere,
and I always use 7D cameras, in 60p
what I want is an option for the 60p to 23.98 workflow that we are used to do in Cinema tools
but in the new system that I will use, Cinema Tools is out.
So thats the situation.
Cheers!
Saludos desde Costa Rica.
Richard Sanchez
on Jul 24, 2012 at 6:08:28 pm
Sounds like you definitely want the console command. Here's a guide full of useful Avid console commands.
http://paul-sampson.ca/AVIDSupport/AVID%20Console%20Commands.pdf
Good luck transitioning! It's really not that bad. I transitioned from Final Cut to Avid last August. Avid's great, you'll love it.
Richard Sanchez
Los Angeles, CA
leo Fallas
on Jul 24, 2012 at 6:10:57 pm
Awesome!
have a great day!
Shane Ross
on Jul 24, 2012 at 6:50:34 pm
The TIMEWARP tool will enable you to bring the 60p footage into a 23.98 or 29.97 project, and then slow it down smoothly, using every frame.
Plus...since you already own FCP and Cinema Tools (you said you were transitioning)...you can still use CT to conform. It didn't stop working.
Shane
Little Frog Post
Rosie Walunas
on Dec 2, 2012 at 1:15:01 am
Hi. Coming from a similar situation.
Just tried this with the TIMEWARP tool. Is re-timing the clip from 200% to 100% or 'slower' right? Anything else to add or consider for quality's sake?
Thanks.
