what codec for DVCAM into Avid using Squeeze?
Matthew Lovering
on Jul 21, 2012 at 3:01:01 am
Hi
I posted this on the Cr. Cow sorenson forum but perhaps it's really an avid question.
I've been given 8 hours of PAL DVCAM footage already digitised off tape and I want to use Squeeze to convert the .mov quicktimes to AVID friendly format. I don't want to link using AMA and transcode later in Avid. I've done this a few times for HD footage - it works well, is faster and lets me control which folders I put the footage in in the main AVID mxf folder, but for SD which codec setting is the most appropriate to use? Avid 1:1? Avid DV100? some other one?
The finished projects will be going onto the web but I'll keep everything interlaced in case someone wants to make a DVD later.
I'm using Squeeze Pro 8.5 and Symphony 6 on a mac.
thanks for any help :)
cheers
Matt
Bouke Vahl
Re: what codec for DVCAM into Avid using Squeeze?
on Jul 21, 2012 at 10:02:59 am
Avid has DV as native codec.
So you could ama and consolidate, not transcode.
This will be lighting fast, and no quality loss.
Bouke
http://www.videotoolshed.com/
smart tools for video pros
