Archival Cut list
Scott Davis
Archival Cut list
on Jul 16, 2012 at 3:43:43 pm
I need to generate a list of all archival material in a show for a producer. In it I need clip name, where the clip starts in the sequence, where it ends, and duration of clip. What would be the best method of getting this to her?
Scott Davis
View Scott Davis's profile on LinkedIn
Shane Ross
Re: Archival Cut list
on Jul 16, 2012 at 5:15:16 pm
Export an EDL. It contains ALL of that information.
Shane
Little Frog Post
Scott Davis
on Jul 16, 2012 at 5:18:22 pm
Is there a way to parse out just the I for I want and get it into Excel?
Scott Davis
Shane Ross
on Jul 16, 2012 at 5:23:02 pm
Move all the clips in the timeline that you want to include to their own track...then export an EDL of only that track.
Shane
Little Frog Post
John Pale
on Jul 16, 2012 at 5:25:50 pm
Duplicate your sequence. Lift/Delete everything but what you want included in the EDL. Leave everything in place, don't ripple. If you need help identifying the material, use clip colors
Michael Phillips
on Jul 16, 2012 at 8:14:26 pm
I use FilmScribe for all that reporting as it allows for TAB and XML. If you're new to it, it may take a little ramp up time to get used to all the different report types, metadata selections, etc. But can be quite powerful once you know it.
See Avid landing page for more info here: http://www.avid.com/US/resources/filmscribe
Michael
Michael Phillips
Scott Davis
on Jul 19, 2012 at 9:40:17 pm
Just a note for future reference. I found an application called "Brewer" http://www.brightscreentv.net
which will take an EDL out of Avid and convert it into an easily readable delimited file that imports into Excel perfectly. Very easy to use and well worth the $30.
Scott Davis
