Avid AMA importing/consolidating issue
Mark Norgate
on Jul 16, 2012 at 10:50:21 am
Having imported an AMA volume and on attempting to consolidate (something which I do many times in a day) I have one clip which wont consolidate and gives the error:
exception: failed to get the sample size from the AMA plugin.
This is the only clip it happens for and nothing has changed from my usual setup. Having browsed forums the only tip I've found is that it's likely an audio problem and to try to unlink and consolidate the video, but unfortunately that didn't work for me and I need the audio also.
Any help appreciated, thanks.
Shane Ross
Re: Avid AMA importing/consolidating issue
on Jul 16, 2012 at 5:15:58 pm
What format are you attempting to AMA?
Shane
Little Frog Post
Mark Norgate
on Jul 16, 2012 at 5:18:56 pm
.mxf from canon CF cards
Shane Ross
on Jul 16, 2012 at 5:58:13 pm
Hmmm....can you play the AMA clip? Scrub it from head to tail.
Shane
Little Frog Post
Mark Norgate
on Jul 16, 2012 at 6:05:45 pm
same thing happens when i try to play it back/scrub in one particular area actually. can i just make a subclip past this point and do it that way?
Shane Ross
on Jul 16, 2012 at 6:17:58 pm
The clip sounds damaged in some way then. Either when it was copied from the card, or recorded on the card in teh first place. I suspect the corruption happened in the copy process.
Try to subclip it. See what happens. If not...try transcoding just that one clip to DNxHD. Avid mixes formats fine...so that one clip being different codec won't matter.
Shane
Little Frog Post
Mark Norgate
on Jul 16, 2012 at 6:23:41 pm
Brill, sounds likely. Will give that a go, thanks.
