Symphony DNxHD to H.264
Terry Leahy
on Jul 6, 2012 at 10:42:19 pm
Quick question. I have a Matrox MXO2 mini on the way and just want to make sure I can use it in the following way. Edit in DNxHD and put in a bunch of different codecs. Export to H.264 Really freaking fast. Put video on Youtube, all while monitoring it on an HD monitor plugged into Matrox box. Yes?
Shane Ross
Re: Symphony DNxHD to H.264
on Jul 7, 2012 at 3:39:45 am
[Terry Leahy] "Edit in DNxHD and put in a bunch of different codecs."
Convert all those codecs to DNxHD...yes. You can't edit all sorts of different codecs native in Avid.
[Terry Leahy] "Export to H.264 Really freaking fast."
If you got the Mini with MAX...yes. If just the regular Mini...no. Need the MAX for this.
[Terry Leahy] "Put video on Youtube, all while monitoring it on an HD monitor plugged into Matrox box. Yes?"
Yes.
Shane
Little Frog Post
Job ter Burg
on Jul 7, 2012 at 9:58:20 am
PC or Mac? I think that the MAX option is more accessible on Mac than on PC.
Terry Leahy
on Jul 7, 2012 at 4:36:55 pm
I did get the mini with the Max and I am running on the latest Macbook Pro Retina Display. I will be editing spots using P2 media (AVC intra) mixed with DSLR. I should be able to convert that quickly to DNxHD and do my edit and then export wicked fast to H.264 so I can get to the upload faster. Will the conversion to DNxHD take a looooong time? I'm just trying to get in a position to edit as fast as possible with file based media and (rarely) a direct ingest from my camera.
