Symphony's Boris
Robert Ober
Symphony's Boris
on Jul 3, 2012 at 1:39:00 am
Hello Folks,
I have the Symphony from FCP crossgrade coming. Is the Boris FX version the same as the version one would buy separately? Is it version 8?
Also, am I correct to understand there is not a separate encoding application with Symphony that does not require a DS?
Robert
Shane Ross
Re: Symphony's Boris
on Jul 3, 2012 at 3:38:14 am
[Robert Ober] "Is the Boris FX version the same as the version one would buy separately? Is it version 8?"
Yes.
[Robert Ober] "Also, am I correct to understand there is not a separate encoding application with Symphony that does not require a DS?"
Normally...no. YOu'd have to buy Sorenson Squeeze separately. But the crossgrade you got also includes that.
Shane
Little Frog Post
Robert Ober
on Jul 3, 2012 at 3:44:24 pm
Thanks Shane,
Just finished reading a review that compared Squeeze to Compressor using a ProRes to H.264 encode. Compressor was cleaner but the tester was able to improve the Squeeze encode with a preset (he called it a filter) that is supposed to help web video.
The reason I asked is that I have Compressor and some others but I not sure I have anything that handles DNXHD but I will look at my Episode 6. Not a fan of the supposedly easier interface Episode uses these days.
BTW, is it the full or the lite Squeeze?
Thanks Again,
Robert:-)
