1080i60 material in a 1080p24 project
Phil Ralet
on Jun 20, 2012 at 4:59:47 pm
I have a 10809 23.976 project for Sony Ex3 footage,
am now beeing asked to import HDV 1080i60 footage ..
my thoughts are to create 1080i60 project, switch to 1080i29.97, transcode to 1080p23.976
any info, thoughts comments appreciatted
MacPro Quad FCP HD, Avid Composer 5.0, AJA Kona
G5 dual 2.5Gig 2.5 gb RAM
OS 10.5.6 FCP 4.5HD, aja Kona 2
Avid Media Composer w/mojo 3.13
Richard Sanchez
Re: 1080i60 material in a 1080p24 project
on Jun 20, 2012 at 5:44:54 pm
Create a 1080 59.94i project, digitize your HDV. Open the bin with the captured HDV footage from your 23.976 project. If you captured at 30i, then do not transcode to 23.976. You will lose your ability to track back and upres. Keep your footage as 30i, Avid will apply a time warp filter to adjust the frame rate. When you are ready to upres, sub sequence out the 30i material and upres that back in the 1080 59.94i project, and drop it back into the mastering sequence. Of course, if your plan is to capture at hi-res, then there will be no upres process, but I still would leave it be and let the Avid adjust the frame rate in the timeline. It does a surprisingly good job considering the math involved.
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
Phil Ralet
on Jun 20, 2012 at 6:29:47 pm
thanks Richard ...
will try this solution ..
MacPro Quad FCP HD, Avid Composer 6.0, AJA Kona
MacPro dual Quad 2.66, 12 gb RAM
OS 10.7.4 FCP 7.0.3.5HD, aja Kona lHi
