Quicktime Error message on Avid Media Composer. Can not get Avid to read .MOV files
Jessica mayes
on Jun 13, 2012 at 7:05:19 pm
I can not get .MOV files imported into Avid. I have only had Avid for less than a day, so I may be overlooking something, but how can I get .MOV files imported on Avid? I can not find the solution online.
I keep getting these error messages, from Avid:
"The procedure entry point QTCF_CFHTTPMessageSetHEaderFieldValue could not be located in teh dynamic link library QTCF.dll "
and
"QuickTime is not installed on this system. It is strongly recommended you install the latest version. Some effects will not function properly without it."
Quicktime is installed. I have uninstalled and reinstalled it but I can not get Avid Media Composer to read the files. Does anyone know why I am getting these error messages?
Stacy Lincoln
Re: Quicktime Error message on Avid Media Composer. Can not get Avid to read .MOV files
on Jun 13, 2012 at 10:49:56 pm
I found a post from someone having a similar problem with a PC. Here's his suggestion:
Do a search on your PC for QTCF.dll. How many copies do you find, and where are they located?
For example, on my PC, I've got one copy at:
C:Program Files (x86)QuickTimeQTSystemQTCF.dll
That's normal.
He suggests you may have a dangling copy of an older version of Quicktime somewhere you need to delete. This search could find it. Worth a try!
