Converting 1080 30p to 1080 60i with specific codecs
Pamela Petruski
on Jun 3, 2012 at 3:56:42 am
I am trying to convert footage that was shot in 1080p30 to 1080i60. The footage was shot on a canon 5d mark ii. I opened the project in avid as 1080 60i. I can't seem to convert the footage to an interlaced format using the codecs I am required to use for this project. I was able to convert the footage to interlaced using the codec DVCpro 50. However this is not HD so I can not use it to turn in as the final export.
I can only use the following codecs/ file formats/ video specs:
video specs- 1080i60 (59.94i) 29.97 fps - drop frame time code
1920x1080
File formats- quicktime(mov.) MPEG-4 1080i60
quicktime(mov.) H.264 1080i60
quicktime(mov.) DVCPRO HD 1080i60
Input into avid as 1080i60 project format, but original footage is 1080 30p. I do not have DVCPRO HD to export.
Please help!
