Symphony 5.5 and 6.0 project compatibility?
Brent Hurlock
on May 31, 2012 at 5:28:30 pm
Anybody had success or failure when moving a project from 6.0 back to 5.5 symphony? I'm sure it will more up.. Can you move one back and forth?
Brent
Shane Ross
Re: Symphony 5.5 and 6.0 project compatibility?
on May 31, 2012 at 6:56:42 pm
As long as you don't use features that are only in MC6/SYMPH 6...such as ProRes MXF...then you would be fine. Newer features never translate back...but Avid has a long history of good backwards compatiblity with most functions.
Shane
Little Frog Post
Michael Hancock
on May 31, 2012 at 7:13:13 pm
Pan and Zoom changed between 5.x and 6. It won't carry backwards (I don't think it carries forwards anymore either - you have reload each picture, I think). Otherwise, you should be fine.
Michael Hancock
Editor
Job ter Burg
on Jun 1, 2012 at 3:21:15 pm
I've gone back and forth quite a bit on two projects over the past months. No issues.
