Avid destroying gradients
Chris Mushinskie
on May 31, 2012 at 3:35:44 pm
I'm having an issue with Avid Media Composer destroying gradients. I have a graphic that was made in After Effects that was imported into the project. The graphic gets really crunchy once imported and exported in Avid. I've tried importing the After Effects graphic in at the highest resolution and at 10 bit. I've tried exporting from After Effects with different color profiles. No improvement.
Then I decided to recreate the gradient within Avid using the marquee. What is strange is that the gradient looks fine within marquee. In fact, I can export out a frame of it within marquee and it looks great:
http://www.tribepictures.com/tmp/From-Marquee.jpg
But if I export that Marquee from Media Composer it looks awful:
http://www.tribepictures.com/tmp/Avid-Export-Marquee.jpg
I've tried exporting from Avid: same as source, quicktime reference, uncompressed...All with similiar results.
I'm working on Media Composer 6, but also have run into this problem in 5.5. I'm not sure what I'm doing wrong. Any advice would be appreciated.
Pat Horridge
Re: Avid destroying gradients
on Jun 1, 2012 at 11:50:59 am
one thing that maybe contributing. are you working in AE in full swing and converting to 601 in MC?
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Donal O Kane
on Jun 4, 2012 at 6:09:04 am
How are you importing the footage from AE into media composer?
All quicktime imports are changed to 8-bit ... except for AMA linking and fast importing of DNxHD codec quicktimes
http://community.avid.com/forums/p/96816/554911.aspx
So going from 10-bit to 8-bit will destroy gradients?
