video capture off by 1 frame
Baz Leffler
on May 23, 2012 at 7:44:31 am
I have found many reports here about this problem but no solutions.
I am trying to capture from a Sony JH 3 deck using a Blackmagic Multibridge Extreme on MAC as PAL. The deck is auto detecting correctly in Avid.
It is capturing 1 frame too early. I can not find any adjustment for it like FCP has.
It is the same on all 3 of my MC6 and Symphony systems.
Can anyone direct me to a solution as I desperately need precise frame accurate capture.
cheers
Baz Leffler
Re: video capture off by 1 frame
on May 23, 2012 at 8:29:48 am
And to add an update - edit to tape (HDW1800) occurs 1 frame late and leaves a black hole of 1 frame. That means that the playback start is 1 frame late as it is the deck that is doing the actual edit from the timecode the Avid sends it.
Daniel Edelman
on Jul 2, 2012 at 7:52:45 pm
Hi Baz,
I'm experiencing a similar problem with my Multibridge Eclipse, specifically during digital cut. Did you ever find a solution?
-Dan
Dell Precision Workstation T5400:
Dual Quad Core Xeon 2.33Ghz
8GB ECC Buffered RAM
nVidia Quadro FX 3700
500GB 7200 RPM System Drive
2TB Internal SATA RAID 0 (2x 7200 RPM Burrered Drives)
Avid MC6
Baz Leffler
on Jul 3, 2012 at 12:33:13 am
Hello Daniel
I reported the problem to Avid and they wanted me to PAY MONEY before they would look into THEIR PROBLEM!
I have since STOPPED using any of my 4 Avid systems and gone back to FCP7 which DOES do frame accurate edit to tape.
I have now reported the problem with Blackmagic who are investigating the problem.
It may help if you also report it to Blackmagic support.
