Splice-In tool (with mouse) with multiple audio tracks
Frederic Lumiere
on May 15, 2012 at 4:21:12 pm
Everytime I feel I'm starting to really know MC, I stumble upon a simple need I simply can't figure out... so I come here!
I've been using the splice-in tool with the mouse and Command key to rearrange clips in the timeline. Been working great. But when I want to move a clip with 1 audio track between clips with 2 audio tracks, the second audio track of the destination doesn't slide. I tried turning on the little hash tag switch next to the track label but it still doesn't slide.
Anyone can help? Thanks!
Mike Drew
Re: Splice-In tool (with mouse) with multiple audio tracks
on May 16, 2012 at 12:37:18 am
Select the blank filler on track 2 with the VA1 Clip and all should work
HTH
Mike
Mike Drew
Avid AE Shake Flame
Frederic Lumiere
on May 16, 2012 at 1:33:36 pm
Ah, I see what my problem is. It's impossible to select the blank filler on track2 with the VA1 clip because it is preceded by a clip with no audio on track2. Even though when I put an IN & OUT at first it looks like it will grab track2 with it but as soon as I drag it, it drops track2.
If the filler is surrounded by audio, then it is possible to drag it with VA1.
Makes sense Mike?
Andrew Rendell
on May 20, 2012 at 7:06:10 am
If the filler on track 2 is part of a longer stretch of filler, you can use the add edit tool to split the filler into lengths that match V/A1, then you can select it and move it around with the other tracks.
