SM_DF_NDF_MISMATCH ERROR merge ALE with AMA clips
Ben Mills
on May 4, 2012 at 1:11:51 pm
Hi there,
I am having problems when merging an ALE with a bin of AMA clips.
The ALE is all present and correct and will import into a bin with the "Maintain events as logged" setting checked.
Unfortunately I cannot use the "Merge events with known master clips" option to merge the ALE with my AMA clips.
I get the error "An error occurred on event #1 Exception: SM_DF_NDF_MISMATCH"
I've tried modifying the AMA clips between NDF and DF but doesnt make a difference!
Any ideas anyone?
Many Thanks.
