Can you make each timeline edit a quicktime chapter marker?
Sebastian Plamadeala
on Apr 30, 2012 at 9:43:48 pm
Can it be done in 6.0 or 6.1?
or at least an edl or ale?
I need to export an h264 mov file with chapter markers
Thank you,
Sebastian
Michael Phillips
Re: Can you make each timeline edit a quicktime chapter marker?
on May 1, 2012 at 1:13:09 am
You should be able to make a basic EDL via EDL Manager and then text edit to make it look like the format supported by Apple Compressor:
http://documentation.apple.com/en/compressor/usermanual/index.html#chapter=...
If you add clip name as a comment, you can have that as part of your text edit as well. Perhaps some has made a text translator already.
Check out solutions at VideoToolshed.
Michael
Michael Phillips
Glenn Sakatch
on May 1, 2012 at 1:51:25 pm
Google is your friend
http://www.evanschiff.com/bd/articles/converting-avid-locators-to-dvd-studi...
Glenn
Michael Phillips
on May 1, 2012 at 1:59:15 pm
I would have offered that link as well, but the original question was about adding chapters to a QuickTime movie, and not an MPEG2 for DVD. Perhaps the unspoken part of the question is that the QuickTime will be used for DVD authoring, in which case your link is the answer.
Michael
Michael Phillips
