AMC 6 . MTS Problem
Lloyd Paul Rivers
AMC 6 . MTS Problem
on Apr 23, 2012 at 5:58:41 pm
Out of about 400 .MTS clips 2 or 3 say they wont import. The import bar gets to around 99.9% then i have an error that says Exception: DISK_DIR_NOT_FOUND, filename:Performance 2.MTS
When i try and link via ama it says There were errors linking AMA files. See the console for details. What is the console? Sorry to sound dumb im a first year editing student, currently on break and my lecturers are not contactable.
One of these clips is a 49 min stage performance which i desperately need.
Any input would be appreciated
Many Thanks
Lloyd Rivers
Juan Salvo
Re: AMC 6 . MTS Problem
on Apr 23, 2012 at 6:35:19 pm
try using mpegstreamclip to extract as much as you can. Seems the files are corrupted.
online editor | colorist | VFX | BD author
http://JuanSalvo.com
Lloyd Paul Rivers
on Apr 23, 2012 at 6:41:06 pm
Tried MPEG stream clip it kept crashing towards the latter part of the process. Got it sorted now i used handbreak.
Any reason for the 1 file in over 400 to become corrupt?
Many Thanks
Lloyd Rivers
Juan Salvo
on Apr 23, 2012 at 6:45:34 pm
Too many reasons. Bad media / bad file copy. 1 out 400 ain't bad.
Did you run repair timecode breaks in streamclip?
Lloyd Paul Rivers
on Apr 24, 2012 at 2:41:15 pm
No i didnt know i could. Fun times now, when i try and export the sequence it says its in an unsupported codec
Update: it says No valid resolution found to be exported using same as source
Many Thanks
Lloyd Rivers
