Avid Media Composer & BlackMagic HD Decklink Extreme 3D Card timecode offset
Pat Horridge
on Apr 20, 2012 at 12:24:06 pm
Have 2 systems set up using the Black Magic Decklink HD Extreme 3D card and both show a 1 frame picture and audio delay compared to the serial deck control timecode when capturing.
This is in SD or HD with no input processing selected from an SDI source.
So capturing an SDI clip with BITC which shows in sync with the deck control timecode after capture and played back shows the picture and audio 1 frame later than the timecode logged with the clip.
Only current solution is to modify the clip and decrement the timecode by 1 frame but that's not really a solution in the real world.
Anyone seeing this issue?
This is with the new 9.5 driver (didn't test on the old one)
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Glenn Sakatch
Re: Avid Media Composer & BlackMagic HD Decklink Extreme 3D Card timecode offset
on Apr 25, 2012 at 5:05:02 am
Pat i finally got a chance to try this at home with my Mac setup. Media Composer 6 with Extreme 3d card.
I am getting the same issue. Have only tried SD from a sony J3, but yes- on tape my slate hits at 01:00:45:00 but the captured footage in Avid shows it at 01:00:45:01. Have also tried capturing the same clip to FCP and Premiere, and do not see the issue there.
Anyone from Black Magic or Avid care to chime in?
Glenn
tyler Granlund
on Jul 23, 2013 at 10:07:20 pm
You guys ever find a fix for this? Im setting up a brand new MC7 system right now with Decklink Studio and my test captures are one from off as well
Pat Horridge
on Jul 24, 2013 at 9:22:27 am
No solution as yet. Basically we can't and don't use the BM cards for ingest. Just too many issues. We have problems with the analogue audio inputs not working as well as the capture offsets.
There's no information from Black Magic at all.
I guess you get what you pay for and with a budget card your saving is the lack of support and development.
